Thong Run
Find Details On Future Meets Planned By eraturbo.com
Thong Run
Post by paul » Wed May 27, 2009 9:32 am
Planning on going to this as only down the road and be rude not to, looks like its going to be a nice weekend planning on camping too!
I see Jeremy is going anyone else?
Re: Thong Run
Post by G96LUE » Wed May 27, 2009 1:22 pm
Not sure.
After my engine probs going to himley hall i realy need to make sure the compression is ok.
Re: Thong Run
Post by paul » Wed May 27, 2009 10:04 pm
Definately going now, MOT'd today passed with a couple of minor things to sort out boosting well with carb back on, has a bit of a mis low down which crept in on the way back from IMM last year and not really been anywhere since then other than a 30 mile slow drive to Stanford hall last year, give it a service and see what I can find wrong.
Jezza
Re: Thong Run
Post by Jezza » Sat May 30, 2009 9:36 pm
Yes we are off to the Thong Run on Sunday around 10 ish so should see you there Paul.
Weather is looking hot so should be good................
Jezza
Re: Thong Run
Post by Jezza » Sun May 31, 2009 9:33 pm
ERA's together on the Thong Run in Kenilworth - see pics.
R1041 sweltering in the heat mid way around the Thong Run route.
My ERA on Thong Run.JPG (79.96 KiB) Viewed 26765 times
Mine and Paul's reunited at the finish in Kenilworth
ERA on Thong Run.JPG (90.93 KiB) Viewed 26766 times
Re: Thong Run
Post by G96LUE » Tue Jun 02, 2009 12:16 pm
Hi Both,
It looks like you had a good day out.
Unfortunately I didn't get chance to do a compression test, but i will try this coming weekend.
I then need to book a day off for a rolling road tune if all is ok.
See you soon.
