this is hor I bought it sat in a corner unloved.
first time it has turned a wheel since 2004.
a quick wash
collection and deliver to new home.
it sat at home till the good weather arrived and I started the strip down.
If only I new this was there a towing eye
start removing the body kit was a mystery in itself.
removes the rusty rear valance
engine removal was not easy so since front panel need replacing made the job easier.
removed the heat shield not a pretty site but could of bean a lot worse
a bit of hard graft with a wire brush
and a quick spray of primer just to protect it.
also removed the sound deadening from under the bonnet.
the only other bad rust is the scuttle which will be replaced
will keep you posted
