Horn
Horn
Post by r1076 » Wed Oct 26, 2011 6:12 pm
were is the horn screwed to??
I just have no idea!!!?
Re: Horn
Post by millermilla » Fri Oct 28, 2011 8:40 pm
The inner wing beside the washer bottle (2 x M8 bolts)
Re: Horn
Post by paul » Tue Nov 01, 2011 12:30 am
bracket of the subframe pointing backwards in front of flywheel housing
Re: Horn
Post by millermilla » Wed Nov 02, 2011 12:12 am
Is that just on a jap ERA Paul as the air conditioning condenser is in the way?
Re: Horn
Post by paul » Tue Nov 08, 2011 10:57 pm
Yup everything is in different places on it, there is no scoop on the back of the grill as there is a A/C compressor there.
One of the aux coolers is further over to clear the compressor too, so there is no where for the horn to live so there is a small extension loom for one wire made and the horn sits low down and so the loom gets pulled of the horn all the time, so I can rarely beep anyone, and even if I can it sounds Sh*T as the horn has had 20 years of splashing about in puddles, the sound is something similar to what I imagine a duck Fa*ting underwater may sound like.
Re: Horn
Post by r1076 » Sat Feb 18, 2012 10:07 pm
can someone please make a picture?
I just can´t find place for it. For fitting beside the washer bottle the wire is to short.
Re: Horn
Post by prop » Sun Feb 19, 2012 1:25 pm
This is taken during the dismantling. I presume it is in the original position
033 (22).JPG (59.25 KiB) Viewed 20519 times
