Meets/shows
Meets/shows
Hi, are there any shows happening this year that would be good to take ERA to?
Re: Meets/shows
If you can provide me with an accurate 4 month weather forecast............ because I try not to take mine out in the rain!
However should the sun be shining the first obvious one in the south is:
National Mini Cooper Day held at the National Motor Museum at Beaulieu, in the heart of the New Forest on
Sunday 14th June 2015
http://www.minicooper.org/index.php/beaulieu1
On Sunday 7th July is the new BMC and Leyland show which incorporates the old Mini show:
http://www.heritage-motor-centre.co.uk/ ... land-show/
I shall be joining the Cowley Convoyers to travel to the show. They are a very friendly bunch and it is great fun starting from the (BMW) Mini plant at Cowley - to register visit here:
http://cowleyconvoy.info/
Should you be tempted to go to unfamiliar territory in your ERA points to consider are:
Venues where access is via a gravel track with pot holes and a ridge up the centre!
Venues where the showground is on grass..... nice cut and rolled parkland is no problem, but meadow like areas where the grass is 6 - 8 inches(15cm - 20cm) will mask bumps and pot holes that you will not see and WILL result in a fractured bodykit as I know to my cost!
Now don't be put off let's get these ERAs out there for people to see!
Re: Meets/shows
They sound interesting Rob-thanks for the info.
I also just found this one: http://www.miniworldlive.co.uk/whats-on-at-the-event
I was attracted to the opportunity for a having a go on the race track....
Re: Meets/shows
Alternatively there's this one a bit later in the year:
http://www.castlecombecircuit.co.uk/eve ... n-days.asp
Re: Meets/shows
We always go to Castlecombe - you should book the day off and come!
