Planning on going to this as only down the road and be rude not to, looks like its going to be a nice weekend planning on camping too!
I see Jeremy is going anyone else?
Thong Run
Re: Thong Run
Not sure.
After my engine probs going to himley hall i realy need to make sure the compression is ok.
Re: Thong Run
Definately going now, MOT'd today passed with a couple of minor things to sort out boosting well with carb back on, has a bit of a mis low down which crept in on the way back from IMM last year and not really been anywhere since then other than a 30 mile slow drive to Stanford hall last year, give it a service and see what I can find wrong.
Re: Thong Run
Yes we are off to the Thong Run on Sunday around 10 ish so should see you there Paul.
Weather is looking hot so should be good................
Re: Thong Run
ERA's together on the Thong Run in Kenilworth - see pics.
- R1041 sweltering in the heat mid way around the Thong Run route.
- My ERA on Thong Run.JPG (79.96 KiB) Viewed 26544 times
- Mine and Paul's reunited at the finish in Kenilworth
- ERA on Thong Run.JPG (90.93 KiB) Viewed 26545 times
Re: Thong Run
Hi Both,
It looks like you had a good day out.
Unfortunately I didn't get chance to do a compression test, but i will try this coming weekend.
I then need to book a day off for a rolling road tune if all is ok.
See you soon.
See you soon.
