25th Anniversary 2014
Re: 25th Anniversary 2014
Fingers crossed it is just the gasket then.
I had a similar water blockage on Julias 1.0 earlier this year, but the blockage was at the heater matrix.
It looked like it was full of salt, it was white and solid.
took about an hour to poke it all out.
I hope mine will be ok, its not moved since march too and then was just for an MOT.
Hope to see you there on Sunday.
Stanford pitch size should be big enough for 12 cars and the gazebo.
Chris still didn't answer my question about arrival time, so i plan to leave mine about 07:15 to be there for about 08:15 - 08:30 all being well.
head and block ok, piston has had detonation next to number 3, not terribly bad but needs replacing.
Dont beleive they are available in standard size any more, but if any one has one I need one!
going back together now.
found auxiallary radiator is block either that or the fitting that looks like a temp switch for aux fan is actually a valve that opens when hot..
Now in the area (nr Rugby) after a gentle mosey up from the deepest, darkest west, and about to prop the bar up for a few.
Definitely won't be the cleanest one on the stand tomorrow - sorry!!
Pulled f93yoe out of storage two weeks ago, after being laid up for over ten years. Managed to mot within a week. I was hoping to drive up tomorrow but its not running great, so I will have to trailer it up. See you all tomorrow.
- image.jpg (105.9 KiB) Viewed 59027 times
- image.jpg (134.48 KiB) Viewed 59027 times
Looking nice and clean now though :-)
Ian has cancelled. I hope everyone else turns up.
See you tomorrow
See you tomorrow
running warmed up nicely no leaks re torqued head, need to do tappets again, quick clean in morning and slow drive on back roads through rugby to stanford hall..
TALLY-HO!
Fantastic turnout of 12 cars today. Thanks all for coming and bringing out your pride and joy.
It was great to catch up with you and meet some new faces too.
I hope you all had a good uneventful journey home.
I will try and upload some photo's tomorrow or later tonight after I have got my holiday stuff ready.
Hopefully we can all catch up next year too.
