Its been very quiet here for a while now so i thought it was about time i did something about it, so here is my latest project.
As you have probably seen from my previous postings, i had to build a new engine for my motor last year. It has now been run in and needs tuning, however i am now thinking of adding a little more power.
i picked up a head of ebay for £34 and have decied to mod it myself.
i have used the photo on the MED website for the profile, and am using Dave Visards "tuning BL's A series engine" for port profiles.
i am hoping i can increase the boost a little.
As you can see from the following photo's, there has been a lot of metal removal.
Hope to see some of you soon.
MORE POWER
MORE POWER
- DSCF6148.jpg (129.85 KiB) Viewed 8013 times
- DSCF6149.jpg (67.76 KiB) Viewed 8015 times
- This is my intended profile
- fis_2.jpg (59.26 KiB) Viewed 8013 times
Re: MORE POWER
chambers 1 & 2 and an MED angle shot
- DSCF6158.jpg (212.52 KiB) Viewed 8010 times
- DSCF6146.jpg (94.55 KiB) Viewed 8011 times
- DSCF6147.jpg (137.7 KiB) Viewed 8010 times
Re: MORE POWER
bad news. After all the work to the chambers, i stared to look a the ports.
unfortunately i found a crack between the inlet & exhaust valve on cylinder 3.
Well it was good practice i suppose.
it looks like it will have to have a rolling road with a standard head for now.
- DSCF6160.JPG (109.6 KiB) Viewed 7967 times
- DSCF6162.JPG (129.88 KiB) Viewed 7967 times
- DSCF6159.JPG (113.39 KiB) Viewed 7966 times
