Speedo Cable
ricke1
Speedo Cable
Post by ricke1 » Thu May 10, 2007 12:33 pm
Hi All,
I need a speedo cable for my ERA R1095
Can anyone Help. :cry:
Era mini turbo
Metro turbo mk1
Meastro turbo black
Montego turbo white mk1
dj clubby
Re: Speedo Cable
Post by dj clubby » Thu May 10, 2007 3:58 pm
hi
try mini spears
GOT BOOST
ricke1
Re: Speedo Cable
Post by ricke1 » Thu May 10, 2007 6:32 pm
I've tried :cry:
Era mini turbo
Metro turbo mk1
Meastro turbo black
Re: Speedo Cable
Post by paul » Thu May 10, 2007 9:10 pm
Looking on Micro Fiche looks like ERA modified part, part number is ERA1302 by looks of things.
I imagine its a standard Mini or Metro Cable with a different end on or adapter on it for the ERA Speedo.
Might be able to replace the inner from a standard cable and get yours working again..
ricke1
Re: Speedo Cable
Post by ricke1 » Thu May 10, 2007 10:00 pm
Yep is a standard length with a different end. I was hoping to use the outer cable, but that is also damaged :( . I need a complete cable.
Or one making :idea:
Era mini turbo
Metro turbo mk1
Meastro turbo black
Re: Speedo Cable
Post by paul » Fri May 11, 2007 8:19 pm
Try someone like speedy cables.
Re: Speedo Cable
Post by G96LUE » Wed May 23, 2007 7:43 pm
Hi Guys
i have searched quite a few places for a speedo cable myself wth no joy.
If you have better luck, let me know.
I got round the problem by using a modern cable (the type with the nylon springy clip). i used my dremel to remove the white plastic then cut two slots in the metal tube end. It is then held in place with a jubilee clip. It is a bit of a codge but it works.
I was told (i think by speedy cables) that if i had the old cable, they might be able to transfer the end to a new cable. as i was building mine from bits i had no end to use. you might have more luck.
cheers
Darren :)
ricke1
Re: Speedo Cable
Post by ricke1 » Wed Jun 13, 2007 11:18 pm
Hi Guys,
Finally sorted my speedo cable problems out, :lol:
My gearbox was fitted with a 3m square drive instead of a 4m drive. Ive replaced it with a 4m one from a old gearbox a had, used i standard mini long inner cable managed to salvaged my outer cable,and it all working fine. :D
Does anybody no why it would have this size speedo drive in my gearbox. :roll:
Ricky
Era mini turbo
Metro turbo mk1
Meastro turbo black
