I need a gasket set, because my era is in the shop and It needs some repairing due to overheating... the only part that i haven't been able to figure out is the block gasket set... do I order the metro turbo set? or is there any difference?
Thank you, and greetings from mexico.
Help! Gasket set...
Re: Help! Gasket set...
The engine in an ERA is a standard metro turbo engine so yes any engine parts for the metro turbo will fit and ERA just fine.
GOT BOOST
