Sticker
Sticker
Post by r1076 » Tue Jan 17, 2012 11:23 pm
has someone a copy of the " ERA - Castrol" Sticker ????
I need one.
deanojr7
Re: Sticker
Post by deanojr7 » Sat Jan 28, 2012 8:47 pm
Hi there.
I have a original unused ERA castrol sticker. when i have time i will try and get some copies made up, they normally have a minimum order of £60 but will ask if they will do a few off
REGARDS R1007
Re: Sticker
Post by r1076 » Sun Jan 29, 2012 8:40 am
That would be very nice.
Thankyou.
Re: Sticker
Post by prop » Mon Jan 30, 2012 2:35 pm
I need one of those + a spare and I suspect others will as well. It gets a bit unfriendly under the bonnet.
Re: Sticker
Post by paul » Tue Jan 31, 2012 9:42 am
I'd love one but there is no where to put it under the bonnet on mine :(
Re: Sticker
Post by millermilla » Tue Jan 31, 2012 10:42 pm
I could do with one if you put in an order.
Re: Sticker
Post by r1076 » Sat Feb 18, 2012 4:52 pm
I know someone who can make them for me.
I just need a good picture and the size.
The best would be a picture with a rule beside.
Re: Sticker
Post by kayball » Wed Mar 07, 2012 2:20 pm
I copied this sticker on to photo paper several years ago. Ratios are correct, colours depend on your printer but you can import it into photo package and modify. I have used it stuck to the engine cover and it does deteriorate, but easy to reproduce again.
Castrol Syntron Label reduced for posting.jpg (62.17 KiB) Viewed 43285 times
Re: Sticker
Post by r1076 » Fri Apr 20, 2012 8:15 am
please give me the size of the sticker.
deanojr7
Re: Sticker
Post by deanojr7 » Fri Apr 20, 2012 3:41 pm
I have tried to put a photo on a while ago but would not down load on to site, file too big.Gave up in the end, didn't forget about the post just had a bit of difficultly.
The picture Pete put on is you best bet but of memory iam sure the sizes are 90mm by 60mm
