Dash Fixing behind Astray
how is the Dashboard fixed behind the astray?
On my Dashboard is a strap, but on my car is nothing to screw it on.
Maybe someone has a pic of it?
Re: Dash Fixing behind Astray
Hello,
Here you go.
Here you go.
- P1000737.JPG (98.58 KiB) Viewed 37152 times
thank you very much.
So, im missing this part also...
Maybe ou or somebody else has a pic of the part itself?
I Hope this helps, Three more photos as well on next reply
Martin
Martin
- 00003.JPG (41.87 KiB) Viewed 37118 times
- 00002.JPG (41.05 KiB) Viewed 37118 times
- 00001.JPG (39.23 KiB) Viewed 37118 times
That's the lot. If you need any more no problem.
Martin
Martin
- 00006.JPG (37.76 KiB) Viewed 37118 times
- 00005.JPG (42.49 KiB) Viewed 37118 times
- 00004.JPG (38.98 KiB) Viewed 37118 times
I was just looking at the brackets and I suspect the silver coloured bracket fits the other way around because there is a mark on the black bracket that fits it in that position. Its a long time since I took it apart and I just fitted the pieces onto the bolts they came off.
Martin
Martin
Excelent pics. Thats very useful for me too. As most of you know mine is a replica and i got the dash off ebay a long time ago.
I only fitted mine with the side two brackets as i didn't know about this one here.
Guess i need to do a little more metal work.
I need to get the dash off anyway as i have a hands free kit and sort out my imobilizer.
Perfect!
Thank you very much for the pics!
This helps a lot!
This helps a lot!
