Air filter options
Air filter options
I wanted to ask members what air filter they use. The original ERA 1103 seems to be NLA.
Have you found another make's filter that fits and what was it ?
Or is there a supply in Japan of new old stock ERA1103's ?
This is for a UK ERA if there is any difference.
Thanks.
Thanks.
Re: Air filter options
I've always used Ford Escort XR3i or Ford Escort RS Turbo air filters, they seem to be the same.
I had the motor factors checking the size of them as Paul had hinted to me they might fit. They reconed they were to big. I will order one an check it out. Thanks.
Hi, i have heard it was an escort RS turbo too.
My car is a replica (as you may have seen) and to try and keep it as close to a real ERA as possible make, i brought an escort RS turbo air box and modified it to get it under the wing.
I then brought a K&N filter for it so i have a filter for life.
When you work out if it the XR3i one or RS turbo one i would recommend you too get a K&N filter to save the problem in the future.
I hope you manage to get one sorted soon.
All the best
All the best
Hi I have just serviced my Era and can confirm that it an XR3i air filter we have an old guy who runs a motor factors and he cross refrenced the fram part number and its XR3i but tryed other places for the same fram filter and they no longer make it.
Think I put a Wix or a Motoquip one in whatever my factor had, they seem a little thicker arround the mounting rubber but went in ok, assume ERA's airbox might have squeezed it a bit over the years.
Thanks for your replys, I did find an original ERA1103 it was very expensive, but needs must. Anyway I have time to sort out another for the future.
As a note the original was made by coopers, no longer listed.
I believe it used to be a Coopers AG416 but I have used a Halfords
HAF 203 (I think) for the last 15 years without any probs. About £5 a poke
Just pulled out the original air filter from my ERA.
It is a Coopers AG416 AKC filter and has the following measurements:
325mm x 125mm x 34mm
