Bonnet latch cable
Thomas_hmlo
Bonnet latch cable
Post by Thomas_hmlo » Tue Apr 21, 2015 12:06 am
My bonnet latch cable snapped and I am after a replacement.
For Japan spec ERA, there is a front mount AC radiator in front.
Can anyone help to shed some light on the correct part to use?
I check the part list and found out the bonnet release cable part number is special prefix "ERAxxx"
My mechanic told me he once tried fitting a 98 Japan spec bonnet cable but it was two inches shorter.
Re: Bonnet latch cable
Post by an old original » Tue Apr 21, 2015 8:06 pm
On the microfiche it shows ERA 5040. the corresponding part from Minispares is GS130273.
http://www.minispares.com/product/Class ... o%20search
or cable only..
You will need to check with them to see if this is the right length, but it is showing out of stock at the moment
