Rear Fogs
Rear Fogs
Post by an old original » Mon Jul 07, 2014 5:50 pm
Anyone got an idea where the in-line fuse for the rear fog lights is?
Whilst replacing one of the lights I know I shorted the circuit and where there was power before there isn't now. Everything else works and if I put power to the back of the switch, the fogs work normally.....ergo..there must be a fuse.....somewhere...
Re: Rear Fogs
Post by paul » Mon Jul 07, 2014 9:48 pm
check for inline fuse behind the plenum there are a couple there I think from memory one is rear fog.
Re: Rear Fogs
Post by an old original » Tue Jul 08, 2014 6:18 am
aahh - hiding away in all the easy to-get-to places!!
Re: Rear Fogs
Post by robr1006 » Wed Jul 09, 2014 9:17 am
The fuse is as Paul has said one of the 3 behind the plenum - should be 10amp and is the one with the blue and orange stripped wire.
Re: Rear Fogs
Post by an old original » Thu Jul 10, 2014 5:22 pm
Sorted - cheers boys
All new light clusters installed on the rear - shiney shiney...
