Hi all, Long time since I posted.
Removed offside body kit last summer due to usual cracking. Bought non-complient base coat and final gloss before it became unavailable, but told it was better than new, water based 'conforming' version.
Cut out all visible cracks down to matting with dremel and then filled with flexible bumber repair paste. (Just been out to garage to try and find old tube, but no joy. I know it was purchased at 'Halfrauds' and think it was Plastic Padding but especialy for repairing plastic bumpers.) Had it resparayed by my normaly reliable contact but he has made a real 'balls' of it. No cracks have appeared, despite trip to IMM, but new paint has not adeared to original. All around edges it has bubbled so it will all have to come off again, but not this weather. It seems that this plastic bumper repair paste is good for repair and is obviously very flexible so will use it again on nearside when weather gets warmer. Will probably try spraying myself before paint becomes time-ex.
As a general note. I have copies of most ERA drawings, including cutting diagram for wheel arch and front panel. I will send copies of any of these drawings direct if you ask. Don't want to publish on site as commercial concerns may make use of them. We changed lowest portion of our front panel due to rusting between body kit and front apron and then, when we tried to refit body kit, found scoops for air inlet and heater fouled lower part of front panel. Hadn't realised that this had also been chopped until then! Chris and I are planning to go to Knebworth Park May 31. Mini and Volkswagon show. (See Greenwood) Anyone else intersted?
pkay@ntlworld.com.
