ARdiator Bracket
ARdiator Bracket
Hi Guys,
I need a template for the stepped Radiator Bracket, as my car doesn´t have its original anymore. Tried to make one, but without correct messurements, the fan hits the Radiator Cowling.
Thanks for Help!
Thanks for Help!
Re: ARdiator Bracket
No one?
Unfortunately my car is about 200k's away and I don't think I'll be there for the next few weeks. I'll measure up mine when I'm next there if someone hasn't given some measurements sooner!
I'll try and get under the bonnet in the next day or 2...
Thanks Guys!
Re: Radiator Bracket
Hi All.
Just found this very rough drawing of Radiator Top Bracket.
I have been intending to tart it up for years but never got around to it.
It was traced from original so if scaled on printer should be all ok to cut. bend positions are critical so note that first bend is 25mm from base of drawing and next bend, the other way is 20mm up from that to give a 20mm deep offset. If you can't read it or have any questions then please e-mail me direct.
Pete Kay (pkay@ntlworld.com)
- ERA Radiator top bracket.jpg (204.1 KiB) Viewed 41114 times
Thank you very much.
I made mine starting with a 1275GT top bracket and added the bends & extra holes. I'm sure that is what ERA would have done too
