bonnet badge
bonnet badge
hi all,
I've been toying with these badges for a bit now and think now they are a good substitute until you can find originals .iam going to list what i have made so far on ebay to try and cover some of my costs and losses, and to see what interest is generated whether or not they are viable enough to still make . see what you think
regards dean
regards dean
- IMG00548.JPG (24.79 KiB) Viewed 26463 times
Re: bonnet badge
they look good....top job (think i may have bought mine off you, way back when)
Re: bonnet badge
thanks for that my first attempt (be great if they were silver just dont think my budget stretches that far) how and where did you get your badge made if you dont mind me asking thanks dean
Re: bonnet badge
I took my original badge(s) into a jeweler/ engraver (Nr Penrith) and he made them up in solid silver...all stamped up.
the price was......er.....not cheap
Re: bonnet badge
hi rob
how long have you owned your car plus do you have any history or letters from ERA as they must have been the first owners
regards dean
regards dean
Re: bonnet badge
Hi dean
I have a lever arch full of stuff on my car.... letters, info and receipts that add up to a small mortgage.
One of the interesting points to note is that mine had a 5 speed box fitted (testing).....it didn't last long!!! I looked into a 5 speeder - newer stronger, but when I spoke to KAD they said they will not guarantee it on a turbo and they said that theirs had not been tested with torque above 130lbs.....so mine was a little too 'feisty' to go down this path.
As far as i am aware (from information given to me) mine is the only one with 'fixed' rear windows...I will stand corrected if anyone knows otherwise?
I have owned the car about 6 years now.
Re: bonnet badge
you own a nice piece of history there that cant be replaced by money, i saw this car in its raw state 13-14 years ago at a mini show wish i made the plunge and brought it then, i dont use mine any more but its still a great feelin when i open the garage .
regards dean
regards dean
Re: bonnet badge
Hi Rob
Mine too has fixed rear quarter windows, F93 YOE. Also was fitted with a Jackknight 5 speed box and tested on the Italian Job run. Both engine and box were removed before being sold by E.R.A
Regards Nigel
Regards Nigel
Re: bonnet badge
hi nigel
its nice that number 4 is still there seen this a few times in the early 90s a chap named gerry from bristol mini owners had it then. just a quick note how many i dont know but the first few cars were tested with 5 speed jacknight gear box and the front suspension were 4" lower than production models number 4 already had several body kits replaced through damage thats why they were hired by 4"
how long and what have you done with it since then regards dean
Re: bonnet badge
Hi Dean
Bought the car from Gerry 18.11.03 drove it home, put it in the garage and that is where it stayed for a few years. At the time i also went to Brighton and test drove J7 ERA but went for Y93 YOE. Have now got the car in storage.
regards Nigel
regards Nigel
